メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年モデルのMac mini(AppleのM1チップ搭載)に関する修理ガイド、分解、トラブルシューティング情報。モデル番号A2348で識別できます。
Mac Mini power plug
Is there some way to stop the power plug from disconnecting from the Mac Mini so easily? Even the slightest shift in the positioning of my Mac, and the power plug falls out. Extremely annoying!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
What is your exact model as Apple has a few different setups. Click on the system icon on the right to see the different series.
さんによる 共有
@danj It's the Apple Silicon M1.
さんによる 共有
コメントを追加
1 件の回答
First off, here's the Apple supplied Mac mini (M1, 2020) Repair Manual
This series uses a standard IEC power cord, here's Apples P/N 923-00645 which you can order but there are cheaper options locally to you. I would try that first.
If a different cord didn't help, then sadly The whole power supply will need to be replaced as the socket is part with it. Here's that P/N 661-16789
Both can be ordered from here Self Service Repair Store for Apple Products
Here's the section which goes into replacing the power supply Mac mini (M1, 2020) Power Supply there's a few steps before the guide will aim you to what's needed.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I don't need to replace the power cable, I just want to know if there's a way to stop it from coming out of the socket so easily. I know that they're designed to release if the computer is knocked over to protect the pins, but mine will pop out if I move the computer even a centimetre or two! It's extremely annoying!
さんによる 共有
@suegarnhum - Yes I got that!
The cord and socket have friction to hold the cord from popping out. Over time this friction loosens! The cords contact clips can also loosen up so the cord may appear to hold fast the contacts aren't making good contact. The cord is often the failure!
Really, the answer is try a new power cord then you'll need replace the socket which here it's part of the power supply.
さんによる 共有
Ahhh, now I understand! Thanks for clarifying that for me.
さんによる 共有
コメントを追加
回答を追加する
Sue Garnhum さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 48
今までの合計 217
