How to change steering oil
@preetsinghmann you will need to flush the steering system and change the power steering fluid. Check this Mitsubishi Lancer Power Steering Components And Function. Since iFixit does not yet have a specific guide for that use something like this video to get it accomplished.
While you work on your car, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their Lancer. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
If you have a Mitsubishi Lancer EX 2013 with hydraulic power steering (most 1.6L and some 2.0L variants), you can change the power steering fluid yourself. If your car has Electric Power Steering (EPS), there is no steering fluid to replace.
Open the hood:
このアンサーは役に立ちましたか?
@dnckigyzh6hy9yk looks very much AI generated. While we do accept AI generated answer we do require the poster of that answer to be transparent and to declare that this is an AI generated answer.
過去 24時間: 2
過去 7 日: 5
過去 30 日: 45
今までの合計 95
2 件のコメント
Hi @preetsinghmann
What is the year of the vehicle?
jayeff さんによる
Can you explain the problem is the steering stiff or make noise when you are at the end of the steering wheel's travel either way?
DanJ さんによる
