Why am I stuck in a boot loop
The laptop is in the boot menu when I press the processor it should boot with it doesn't
Well I will suggest you to checkout the following guide: https://www.systweak.com/blogs/fix-compu...
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 4
過去 30 日: 25
今までの合計 168
1件のコメント
Hi @johnoybeckford
There's only one CPU in the laptop.
Can you get into BIOS OK on startup?
Have you got 2 Operating Systems installed in the laptop e.g. Windows and Linux in a dual boot arrangement?
If so are they on the same SSD (different partitions) or have you installed a 2nd SSD in the WWAN slot where one of the OS is installed?
Which OS is not booting?
jayeff さんによる
