メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PS4コントローラー、モデルCUH-ZCT1。2013年11月にSony Computer Entertainmentから発売。6軸センサーと3.7 Vリチウムイオンバッテリーを搭載したこのコントローラーは、修理が容易です。(注:分解ガイドは本モデル用ではありません)
Am I soldering correctly?
This more of a general question I feel like I'm soldering at a too high temperature I keep damaging the mask around the vias sometimes stripping the mask around the vias revealing the copper I don't know if that compromises the connection or not at what temperature I should solder at? I currently solder at 400c I use both lead and lead free solder.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi @christophe89153
Sounds like you're applying too much heat. Either that or you're applying it for too long.
Are you "tinning" the via first, before soldering it to the board?
Tinning means coating the part of the wire that you wish to solder with a thin layer of solder. Easiest way is to melt some solder on the tip of the soldering iron and then pass the part of the wire that you wish to solder through the molten blob of solder so that it gets a thin coating of solder. Then when you go to solder the wire to the board you only need a minimum amount of soldering time for it to solder onto the board.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
In my previous attempts I wasn't thinning the vias, but I was using flux. I have started to thin with low melt solder and got better results. I have 90w solder iron station and it can easily melts the low melt solder at 200c
さんによる
コメントを追加
Can you give a picture of what you are trying to solder? What type and wattage is the soldering iron you are using? 70W-90W will take care of most circuit board soldering. 320C -350C is probably better for small components. You are likely too hot.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have a 90w solder station I'm soldering anything from batteries for cartridge games that use one to analog sticks for controllers
さんによる
@christophe89153 That should work with a good clean tip (small chisel type) . I think your temp was a bit high. Much higher than I ever use.
さんによる
コメントを追加
回答を追加する
Christopher D さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 25
今までの合計 168
