メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Loose USB-C charge receptacles
Both USB-C side-by-side charging ports will charge laptop only if wiggled, and no power light next to ports. Need part number, and whether this is a pluggable part, or requires soldering. Thank you! A part picture would be handy.
Found that even though connector seemed fully inserted, it was not. Cleaned receptacle with narrow, stiff brush, and contact cleaner several times ...it is now charging again.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@m7vtuqoqzqrwbhl those ports are commonly soldered to the motherboard. WE will need to know your exact computer model as well as what motherboard it has. That way we can most likely find replacement ports. It may also be possible to just resolder the ones on your board. wE will have to see all of that to be certain. Post some well focused pictures with your question so we can see what you see.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
C H さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 83
