メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年3月のアップデートではアップルの13インチMacBook Airは第5世代Intel Core i5またはi7プロセッサーを特徴としており、これによりわずかな性能とバッテリー駆動時間の向上がされました。
Delayed Keyboard Response if anything at all.
2015 A1466 MacBook Air 1.6 GHz 8 GB RAM
I swapped over the keyboard / TP cable 4x with new parts
Changed 3x complete keyboard assemblies (All with new keyboards)
Using new track pads / Clean install Monterey 12.7.6 and was able to complete setup and all seemed OK but I noticed the keyboard response was delayed...... now next to nothing going on when I reboot and try to login.
Keyboard isn't responding and when it does it is 5 seconds late in displaying 'some' keys. Cables are seated and latched correctly etc. Connector looks clean (I have cleaned it out, no dirt and dust under the microscope) I have even put the SSD into another unit to check the OS, ALL fine!. This is driving me nuts.
Must be a board issue..... but it is working fine other that the KB issue.
It is 100% NOT in the dreaded CPU safe mode state. Any ideas?
UPDATE: It magically fixed itself. (Stuck right side command key!).
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
6 件のコメント:
Try to see if you get the same response from an external keyboard. Also, did you replace the trackpad flex cable? The keyboard actions route through the trackpad and then into the motherboard. Comment back here so we can fix this.
さんによる
@somerandomguy_1 Read again, 4x new cables, 3x new KB's, etc etc.
さんによる
@livfe Ah, yes, my bad! I don't know what it could be other than a faulty motherboard connection to the keyboard cable.
さんによる
@somerandomguy_1 That is my thoughts also.... I can only transfer the board into another shell from a fully functional unit to see if that is the issue... mind blowing this one.
さんによる
@livfe logic board is a 820-00165? ;-)
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
See if the external USB as well as a Bluetooth keyboard is responsive. I'm suspecting the logic board it's self has an issue. You may want to see if diagnostics works without error.
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
I plugged an external keyboard (new bought today) and it didn't get me into diagnosis mode, but the laptop booted as normal and it was working fine. I $@$* down, restarted with no external KB connected & it went directly to diagnosis! When diagnosis completed, it went to auto boot (no apple logo) to recovery mode!!. Shut down, restarted normally, keyboard working normally. It fixed itself seemingly, after 2 days of swapping this and that over to find the culprit. As Alex says, Amazing.
さんによる
@livfe - So a bit of magic then😁
All's good?
さんによる
@danj Yes it must have self healed or no longer wanted my magic touch!
(Stuck right side command key (I always used the left side one!).
さんによる
@livfe - Now you know why I love testing with externals with cases like this.
Here the Keyboard driver was messed up, by forcing the OS to use the external, the driver issue could fix its self.
さんによる
@danj Thinking back, I swapped over a few KB cases with new KB's and all were the same, so it wasn't a 'stuck' key.... Maybe the external kicked something back into action, but it never fixed itself immediately after the external KB was plugged, It still took a few restarts with no resolve. Still somewhat of a mystery, perhaps Siri read my mind as I was thinking 'Your going to be scrapped for parts & the rest of you to the Mac Graveyard' lol (Even though, to this day, I have NEVER turned Siri on).
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
livfe さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 121
