How to change bits?
how to change bits?
Have a read of this manual. The very front piece should come off. Either twist off or bayonet fitting. The the next section comes off.
このアンサーは役に立ちましたか?
The collar comes off if you pull forward, revealing the bit holder. To put it back together you just need to line up the ribs on the collar with the grooves on the machine. I added the relevant photos
Hope it helps!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 35
今までの合計 152
