メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
NintendoのSwitchシステム向けに製造された、ワイヤレスで従来型のビデオゲームコントローラー。モデル番号:HAC-013。
Bit not long enough. Solutions?
Trying to disassemble a Pro Controller to give it a thorough clean and sanitizing, and the screws behind ZL/ZR are too deep for the precision bit screwdrivers. Are there any solutions that don't require me to buy another screwdriver?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
So, this solution relies on you having access to a kit with 4mm hex bits, but it's one I use all the time: you can one of those and stick a bit in it, and voilà! You've got yourself a slightly longer screwdriver, capable of reaching just a little further than before! There's just two things to consider here. One, depending on the width of the recess, the 4mm hex socket may or may not fit into the hole, and two, all of this is assuming you're using 4mm bits to begin with, so there's another way I've used that works on any size of bit. Basically, you have to drop the bit in the screw recess, then carefully slide the driver onto it without it fully fitting to the bit. This is really tricky with bits that are held in by magnets, but it's easy with a snap-fit bit. Either way, you have to slide the driver onto the bit just enough that it engages and can turn the screw. You'll no doubt have to do this multiple times per screw if you're using the aforementioned magnetically secured bits, but probably not as much if they're snap-fit. If none of these methods work for you, well, you could always use a drill if you had to, although I probably wouldn't try it unless you're out of options, as it risks stripping the screw or the bit.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I did manage to get it *in*, but it popped as soon as I turned it. I got stinkbombed by the controller anyway, so I'm just gonna figure out what to do with it.
さんによる
コメントを追加
回答を追加する
Far Too Many Frogs さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 157
