メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to replace display hinges?
I currently daily drive an HP elitebook 1030 g8, and have recently noticed that he hinges have seriously deteriorated! To the point where several angles beyond 150 degrees will cause the display to fall flat.
I have 2 other systems that may provide me with the parts to solve this issue:
Elitebook 1030 g4
Elitebook 830 g8
If either of these are suitable for a replacement, and you know the method to engage this process please help!
I also do need directions on how to execute this repair because little/no repair material is available online.
Thanks for the support!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi!
To change the hinges, there's two ways.
Either (the more common) is to replace the whole top section with both frame and display. If you would want to do that then HP's maintenance and service manual should suffice, I've linked you to the display disassembly section.
If pdf link breaks, you can find the maintenance and service manual among the manuals and guides on HP's Support page for your device.
The other way is by replacing just the hinges. You would then need to follow the maintenance and service manual to take of the display assembly, and then you would also need to remove the monitor from the frame, which HP EliteBook x360 1030 G3 スクリーンの交換 shows how to do (similar model). I also found this Youtube video which shows the same thing.
Where to find parts is something we does not always do, as availability and different region means that a market for me likely won't work for you. So my recommendation would be to use your favorite search engine and search for "HP elitebook 1030 g8 hinges / screen assembly / display replacement" in ordered to get localized results that works for you.
Good luck with this,
Cheers
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Thanks! Ill make sure to try this Asap.
Of course im going to wait until I have the hinges so I will not be able to give feedback immediately.
さんによる 共有
@meekvixen just add the complete document to your answer. Then we don't have to worry about link rot in a few years/months or whenever the OEM decide to retire the link :-) HP EliteBook X360 1030 G8 Maintenance And Service Guide
さんによる 共有
Do you know how I attach a file to the issue? I have the PDF downloaded, but do not know how to attach it
さんによる 共有
@oldturkey03 Wow, thank you! I've never thought about that, I'll keep it mind from now on :) Thanks
さんによる 共有
@briandauber For updating a question with media you can follow this guide: iFixitでの質問に画像を追加する方法
Although, oldturkey has a attached a link to the document, and uploaded the document to the [[Topic:HP Elitebook x360 1030 G8]|device page|.
さんによる 共有
コメントを追加
回答を追加する
BlueSpaceCatno2 さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 10
過去 30 日: 56
今までの合計 331
