Is there a LCD and Digitizer replacement guide?
i'm trying to find a lcd and digitizer combo and installation guide.
No luck locating a written guide, but this YouTube video seems to be reasonably well done and has all the information you should need to remove and replace the LCD and/or digitizer.
iPad 10 Screen Replacement Guide – Tools, Tips, and Color-Coded Screw Locations! - YouTube
このアンサーは役に立ちましたか?
Hi, @apollo5727 I gotchu.
We could not find a guide, but you can try doing this:
1: Use the iOpener and heat the side of the iPad, then insert an opening pick 3mm inside. Repeat this for the other sides, trying to not interfere with cables.
2: Lift the iPad digitizer assembly, then you will reach the LCD. Unscrew the screws using a 00 Phillips driver. Then lift the LCD.
Please, if you can, give us a guide about this repair. How to start a new guide
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 22
今までの合計 154
