メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
SonyのDualSense Edge (CFI-ZCP1) ワイヤレスコントローラーは2023年1月に発売されました。交換可能なジョイスティックモジュールや、DualSenseからアップグレードされた機能を備えています。
Fn button stuck in pressed state
Pad just stuck in profile select mode due to always pressed right Fn button, I swapped the modules and even bought new ones, but it didn't help.
画像
also i have this: 0300e0274c050000f20d000000016800,*,a:b0,b:b1,back:b4,dpdown:h0.4,dpleft:h0.8,dpright:h0.2,dpup:h0.1,guide:b5,leftshoulder:b9,leftstick:b7,lefttrigger:a4,leftx:a0,lefty:a1,rightshoulder:b10,rightstick:b8,righttrigger:a5,rightx:a2,righty:a3,start:b6,x:b2,y:b3,touchpad:b11,misc1:b12,paddle1:b16,paddle2:b15,paddle3:b14,paddle4:b13,crc:27e0,platform:macOS,
So the main question is how to understand what exactly the problem is next, and what to change, since this is definitely not a problem with the stick module.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi!
Then it's most likely something on the board.
Try to clean the connector and inspect if there are any bent pins.
If it's bent, try to fix it.
In the worst case, you need to replace the port or replace the board.
Guide: DualSense Edge 基板の交換
If possible, can you sent us some pictures regarding the joystick port?
Thanks!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Actually, it sat for almost a year after I bought it. I simply forgot about it. It only showed up after 4-5 days of use, and I didn't have time to replace it. I cleaned the connectors with rubbing alcohol, but everything was still the same. I'll post a photo later, I'm not at home right now. I also thought it might be the motherboard, since there's nothing else there that could cause this. And thanks for the reply! I'll send photo as soon as I get home)
さんによる
Thank you! That is most likely it yes. Nothing else should be able to cause this, so far I'm aware of.
Please let us know when you have an update :). Thanks!
さんによる
コメントを追加
回答を追加する
Granchik さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 25
過去 30 日: 126
今までの合計 677
