メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Realme 9は、Realmeが設計し2022年に発売されたミッドレンジスマートフォンです。
My phone not speaker
Mere phone me avaj nahi sunai deti hai
Update (04/14/26)
  1. Mere phone avaj nahi sunai deti hai
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント:
Power button dabane me nhi khulta
さんによる 共有
Display remove in phone
さんによる 共有
Mere ka mic kaam nhi karta
さんによる 共有
Speaker mein awaaz bahut kam aata Hai
さんによる 共有
コメントを追加
1 件の回答
@princekuma96001 @rohitkewat no sound or low speaker volume is usually caused by clogged mesh, an audio setting, or a failed speaker module. Since no one mentioned which speaker is low volume or not working, you have to determine if it is the earpiece speaker or the speakerphone one. Make a call and toggle the toggle Speaker on and off. If the call is quiet against your ear but loud on speakerphone, the top earpiece is the problem. If music, ringtones, and speakerphone are all quiet, focus on the bottom loudspeaker.
Also clean the speaker mesh with a clean, dry, soft-bristled brush. Do not poke anything into the mesh holes as you could damage the speaker.
Next make sure that this is not a setting issue. Turn off Bluetooth to make sure the audio does not accidently gets routed to any previously used earbuds or speakers etc. Next go to Settings ==> System/Additional Settings ==> Accessibility ==> Hearing and make sure the Audio balance slider sits in the middle. Then open Settings ==> Sound & vibration and raise Media, Ring, and Call volumes separately. Now play a video or audio and see if that made a difference.
If not then you know the issue is not a settings issue but it is hardware related. You will have to replace the speaker module. Since iFixit does not yet have a specific guide for this, use something like this video The bottom speaker is shown at 4:22min and you can see the earpiece speaker in the last minute after removing the main board. It is the part in the top center position.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person who has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Prince Kumar さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 18
過去 30 日: 46
今までの合計 438
