メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GoogleのオペレーションシステムであるChromeOSで動作する、軽量で手頃な価格のノートパソコンです。このChromebookは主に学生や教師による使用を想定して設計されています。
Hardware Write Protect Removal
how do i remove the hardware write protect? im trying to put linux on it and replace chrome os completely
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
These are CR-49 based - they use a SW WP which has to be disabled in Dev mode as well as a physical screw in many cases - the usual tell for the WP screw is it's a ground and it tends to be non anodized and you will not see solder mask. The other rub is if it has MDM, you usually cannot access dev mode with it blocked. You need to run this once the screw/battery protection is defeated: flashrom --wp-disable
画像
-- this is where it appears to be on this model. Some of these CR-49/50 devices use the battery instead of the board, with some only responding to this cable: SuzyQable
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
so i already disabled the sw wp but the hard ware wp is still on now i have already disconnected the battery so that means i have to use a suzyQable correct? or would it be a jumper it keeps failing to update the wp setting and i used a command and it told me the hardware wp was still active
さんによる 共有
@williamnissen As long as both are done you need the SuzyQ, if yours can take an alt Linux on the Google BIOS - these can't be flashed with Mr.Chromebox due to the ARM BIOS. Your might use screws and the battery then.
さんによる 共有
コメントを追加
回答を追加する
William Nissen さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 63
今までの合計 439
