メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2023年9月22日に発売されたAppleの最上位フラッグシップスマートフォンiPhone 15 Pro Maxの修理・分解・トラブルシューティング情報です。6.7インチのProMotion OLEDディスプレイ、新しい光学5倍ズームの潜望鏡付きトリプルレンズリアカメラシステム、5Gを搭載。iPhone 14 Pro Maxの後継モデル。
Back Glass Replacement - Wireless Charging Coil Transfer?
I’m replacing the back glass on an iPhone 15 Pro Max. I was wondering if the wireless charging coil is something that I am able to transfer from the original? If so, is it just a heat and carefully separate situation? Or is this a component that will require soldering to fully transfer?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
The repair required the complete removal of the wireless charging connector and its associated components from the back panel. Following the connector (using heat and an ifixit pick), I slowly peeled the assembly away from the back glass. All in all the assembly includes the camera flash, the wireless charging coil (extremely delicate), and the connector. If it’s removed carefully and installed in the new part, you can avoid any need to run repair assistant and there won’t be the automatic record of the repair in your settings when you complete the process.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Did you review the iPhone 15 Pro Max 背面ガラスの交換 guide the coil is part of the back glass the replacement will snap into the connector which you can see in Step17 ~ 19
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@danj thank you for your reply! Unfortunately, the repair I was performing was from the original unit to an aftermarket back panel. The repair required the complete removal of the wireless charging connector and its associated components from the back panel. Following the connector (using heat and an ifixit pick), I slowly peeled the assembly away from the back glass. All in all the assembly includes the camera flash, the wireless charging coil (extremely delicate), and the connector. If it’s removed carefully and installed in the new part, you can avoid any need to run repair assistant and there won’t be the automatic record of the repair in your settings when you complete the process.
さんによる
コメントを追加
回答を追加する
Luke Grimes さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 45
過去 30 日: 127
今までの合計 529
