メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Itel L6502はItel Vision 1 Proとも呼ばれ、2021年1月に発売された低価格スマートフォンです。6.52インチの大型HD+ディスプレイを搭載し、2GBのRAMを備えた基本的なクアッドコアプロセッサで動作します。一般的に最適化されたAndroid 10 (Go Edition) オペレーションシステムを使用します。
How to fix the charging system
How to fix a charging system port
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
5 件のコメント
how to fix charging port
さんによる
@zai6292 See the charging port replacement video posted in @oldturkey03's answer.
さんによる
Charging system is disturbing me I would like to repair
さんによる
How to repair the charging point
さんによる
Show me Counties the screen
さんによる
コメントを追加
2件の回答
最も参考になった回答
@mainalyton you are not telling us what the issues are (I assume it is not charging) nor are you telling us what you have already checked and tried. Of course, you always check your charger and your charging cord. Make sure you have the proper voltage and that your cable is in good working order.
Next, you want to check your charging port. Make sure that it is clean and does not have bent pins. Use a few puffs of canned air to clean out any pocket lint etc. If all of that is okay, then a charging issue can be caused by a bad charging board, a bad battery or a bad cable from the charging board to the mainboard. I would start by replacing the battery and the charging board at the same time. That way you only have to open your phone one time.
Since iFixit does not yet have a guide for that use a combination of this video for the charging board, as well as this video for the battery.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Open the phone and remove a panel and use a hot air station to replace a pot
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Maina Lyton さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 22
過去 30 日: 56
今までの合計 644
