メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JBLヘッドホン用の修理情報、サービスガイド、交換パーツ情報。
JBL Quantum TWS - Battery
Hi,
I would like to ask, if you would know which specific battery is placed in the JBL Quantum TWS, earpiece and case. These had catastrophic battery failures but I would like to try and repair them with new ones.
Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
I just tried with mine - I have problem with actual earbud's battery - it does not last long anymore.
It's not hard, but you should be careful. The insides are glued together, but I was able to open it just with my finger nail.
Afterwards, you unplug the pin and push board up. Better start doing it by pushing charger pads with a something thin, to avoid breaking them (that what happened to me, however should be easy to solder them back).
Battery itself has marking 0.196WH Li-ion VDL 1240H, however I was not able to find exact substitute, will try some other battery of a similar size e.g. LIR 1240.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi,
Thank you for the information! This is super helpful. I have also found some information on the battery in the manual, but I wasnt able to find any suitable substitute.
Edit: Adding link
https://www.manua.ls/jbl/quantum-tws/man...
さんによる
コメントを追加
回答を追加する
Padouch さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 51
今までの合計 162
