How to replace an HDD with an SSD?
Hello, I have an old laptop and I want to play Minecraft on it, but its performance is unstable. The AI says I need an SSD to improve performance. How can I do this?
@roman88534 use the HP 250 G1 Maintenance And Service Guide to work on that. Something like this video will work as well. Remove the HDD and replace it with a 2.5-inch SATA SSD. Of course, back up your HDD first. Once you have the SS installed you would need to install the OS. Or you can keep your files and OS by cloning the old drive before replacing it. For that you would need some cloning software and a USB-to-SATA cable to clone the old drive.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 71
