System Corrupted Issue Prompt
There are times that my phone suddenly turns off, and when I open it, there's this prompt that says system corrupted.
If this happens only sometimes, go into settings and make sure you update to the latest Android version.
If it consistently happens, or the above had no effect:
Turn off your phone, press the volume down key and the power key, to boot into recovery mode. Then factory reset your device. If you have backed up your phone through Google, then you should be able to bring back all of your files.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 9
過去 30 日: 36
今までの合計 160
