Why is my computer overheating?
My dell computer is overheating even though I cleaned the fans a week ago. And it just keeps turning of when on for 3 min. Can someone please help me?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
This sounds like a thermal throttle issue, disabling your computer again and checking thermal pads and thermal paste is your only good option. Make sure you did not bend your heat pipes either as that can cause “lift” on the CPU where the heat sink appears to make full contact but doesn’t actually.
このアンサーは役に立ちましたか?
If your Dell computer overheats and shuts down within minutes, the issue may go beyond dusty fans. Check if the CPU thermal paste has dried out—reapplying it can significantly improve cooling. Ensure vents are unobstructed and the cooling fan is actually spinning. Use a hard, flat surface (not a bed) to allow airflow.
Also, scan for malware or heavy background apps causing high CPU usage. Update BIOS and drivers. If overheating persists, the heatsink or fan might be faulty, or there could be a motherboard issue—professional servicing may be required.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 16
今までの合計 156
