メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
12インチ画面搭載のHP Spectreノートパソコンの修理ガイドとサポート情報。
Why does my pc fail to boot successfully?
画像の内容を見る:
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hi @onyandostephen
The laptop's BIOS cannot find a boot file to load i.e. either the boot partition in the HDD/SSD is corrupted or the HDD/SSD has failed.
The message on the screen shows that the BIOS has gone through all the available boot options e.g. HDD/SSD, USB etc and didn't find a boot file and has ended up on the last option (PXE input) which is to boot from a network Ethernet connection which is also not there.
PXE connection means that the OS is located on a server somewhere else and not in the laptop on the HDD/SSD, This is mainly used by businesses where employees' PCs are all connected to the one mainframe computer.
Check in BIOS to see if it shows that the HDD/SSD is detected or not.
If it is shown in BIOS then there's a problem with the boot partition in the HDD/SSD - corrupted data perhaps
if it isn't shown in BIOS then there's a problem with the HDD/SSD - loose, failed or a motherboard problem.
What is the full model number of the laptop as shown on the product information label on the bottom of the laptop?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
PC boot failure is usually caused by power supply issues, loose components (RAM/GPU), or corrupted system files. Immediate steps include checking power cables and switching on the PSU, resetting RAM, and checking BIOS for drive detection. Corrupt Windows files, wrong boot order, or failing hardware (hard drive/motherboard) often stop the system from loading.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Onyando Stephen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 47
今までの合計 246
