Refrigerator has error code 41
How to fix error code 41
Hi @marko51520
On p.79 of the service manual it shows that an error code 41 is a Main ↔ Panel (F-HUB) Communication Error and to replace both boards i.e. main control and display board.
Perhaps check if the cable connection between both boards is OK first.
The cable runs through a connector at the right rear of the refrigerator so perhaps check if that is OK too. See the wiring diagram on p.135 The F-Hub panel board connector to the main board is CN1300
このアンサーは役に立ちましたか?
過去 24時間: 7
過去 7 日: 11
過去 30 日: 48
今までの合計 306
