How do you replace the battery?
Battey is discharging much quicker than when it was new. How do you replace the battery?
Hi, @ike3216 I gotchu.
FixBot said that you must heat the back cover, then you must use that Phillips screwdriver to open the shield plate, and of course, disconnect and remove the battery using our spudger set.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 21
過去 30 日: 75
今までの合計 738
