メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年11月に発売されたPlayStation 5は、グラフィックが大幅に向上し、革新的なDualSenseコントローラーを搭載しています。近未来的な白黒のカラーリングは、これまでのPlayStationのデザインから大きく逸脱したものです。
PS5 LAN Disconnecting/Reconnecting Repeatedly
I’ve been experiencing an issue with my PS5 where the LAN (Ethernet) connection repeatedly disconnects and reconnects almost instantly. This happens back to back , mostly within the first hour of turning on the console and starting a game. Sometimes it temporarily stops, but then the issue returns.
I’ve already ruled out the Ethernet cable by testing with another one, and I’ve seen others report similar issues online without a clear solution.
Side note: my HDMI port is loose, and I have to angle the cable for a stable display connection. I’m wondering if there could be any relation between the two issues maybe heat, board stress, or internal damage affecting both ports.
Would it make sense to replace the HDMI port first and see if that resolves the LAN issue, or is this more likely related to the Ethernet port or its solder connections?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I would bet its a heat-related situation. Especially if your console is fixed in the Vertical position, as this places the ether net port at the top edge - sitting directly above the ports where the internal fans vent excessive heat generated during gaming.
Had my PS5 since 2021, expanded my internal storage for an additional 2TB - and after 5 years, this bullshit starts happening? Conveniently enough, just in time for GTA6 to create enough hype that to cause a greed-driven inventory crisis (AGAIN !!!) for the 2nd time, since Covid - so the current scalp-rate has the cost of a PS5 Pro now fixed at the (currently) all-time-high price of $1,399 (a $100 increase from $1,299 - within the last 30 minutes...and apparently, this is the "last 1 available" - thanks, Amazon 🖕🖕🖕)
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi!
First of all, I don’t think it’s related to each other, BUT I would fix it anyway.
You either need to replace the HDMI port or maybe you can solder it in again for good.
Replacing the LAN port is also recommended. I’m afraid it’s the port it self. I would fix it at the same time and see how that goes!
Be aware, both jobs are difficult… maybe asking a repair shop would be a good thing to do.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Moose さん、ありがとうございました!
統計データ:
過去 24時間: 18
過去 7 日: 123
過去 30 日: 486
今までの合計 1,517
