メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Envy x360は、2014年から同社が製造しているノートパソコンシリーズです。タッチスクリーンと回転するディスプレイを搭載しています。
Why does keep occurring even when saving videos
every time i attempt to save either images or videos and yet this happens why does it keep occurring what is the cause and the solution
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
The error code 0xA00F424F occurs because the Windows Camera app cannot find or access the
folder where it is supposed to save your photos and videos (typically the Camera Roll folder).
This is usually caused by the folder being accidentally deleted, moved, or having incorrect permission settings [1|new_window=true].
Solution 1: Manually Recreate the Camera Roll Folder
The most common fix is to ensure the expected folder exists in your user directory.
  1. Open File Explorer.
  2. Navigate to your Pictures folder (usually C:\Users\[YourUsername]\Pictures).
  3. Check if a folder named Camera Roll exists.
  4. If it is missing, right-click in the empty space, select New > Folder, and name it exactly Camera Roll [1|new_window=true].
  5. Restart the Camera app and try saving a photo.
Solution 2: Change Where New Content is Saved
If recreating the folder doesn't work, you may need to tell Windows where to save new files.
  1. Press the Windows Key and go to Settings > System > Storage.
  2. Click on Advanced storage settings (or "Change where new content is saved" on older versions).
  3. Look for New photos and videos will save to:.
  4. If it's set to a drive that isn't available (like an external drive you unplugged), change it back to This PC (C:) and click Apply.
Solution 3: Reset the Camera App
If the app configuration itself is corrupted, you can reset it to factory defaults.
  1. Go to Settings > Apps > Installed Apps (or Apps & Features).
  2. Find Camera in the list, click the three dots (or the app name), and select Advanced options.
  3. Scroll down and click Repair. If that doesn't work, click Reset [2|new_window=true].
Hardware Note for HP Envy x360
While this is primarily a software issue, if you continue to have trouble with your camera hardware (such as the indicator light not turning on), you can refer to the official maintenance guide for your device to ensure the internal module is seated correctly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my built in laptop camera won't save pictures, it gives me an error code 0xA00F424F<PhotoCaptureFileCreationFailed> how can I fix this problem
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Matt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 124
