メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nintendo GameCubeは、任天堂の4番目の家庭用ゲームコンソールです。修理は簡単で、一般的なツールだけで行えます。
Disc board fails to spin disc
I've got a gamecube with an interesting problem. I have another cube that is known working and I've done part by part swaps (motherboard, disc motor, hinge switch) to narrow down my issue. Something on my disc drive board is wrong and it will not spin the disc. Changing the motor to my known working cube proves the motor isn't the problem. I even swapped the good motor to see if that will work, which it didn't. I have a cheap multimeter and the caps are taking a charge and discharging as normal. A reflow of the hinge connector has not fixed my issue. I'm at my wits end and about to call it a lost cause.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi!
Pretty sure that the caps failed on the disc drive board…
I would replace them and see what happens.
You can find the kit here: https://console5.com/store/nintendo-game...
Please let us know how it goes!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
D2 the Hobbiest さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 156
