メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Ford Mustang(第4世代)の修理ガイドとサポート。Mustang GTやMustang Cobraも対象。
Have low fuel pressure
Have changed fuel pressure sensors on fuel rail and on gas Tank .Have changed fuel pump .cranks after priming (turning key on and of 3 times ) and ideals if you press the accelerator like normally taking off it will die if you put it in gear and press the accelerator it will die if you slowly float the accelerator and park it will rev up all the way to 3500 RPMs but once you put it in here and mash the gas to go it stalls out. When you just crank it and let it sit there and Auto it autos for a while then it will all of a sudden start missing bogging down and die
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
@martyleesmith what exact year and engine size is your Mustang?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
I had a suburban that acted like this. Had me chasing ghosts thinking it was fuel. What fixed it for me? Oddly enough.... spark plugs. It would fall flat on its face unless i was in park. Then I could get the revs up a bit more. I replaced the fuel pump, filter, all that jazz. No difference. Then I replaced the plugs, and it immediately stopped all of that.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Marty Lee Smith さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 26
今までの合計 114
