Why the air compressor not starting?
Why air compressor not starting
@innocentmutepfa start by checking fuse #28E which controls the compressor clutch relay. If your fuse is good, you will need to check the relay. Here is the Land Rover Discovery 4 HVAC Wiring diagram. Use that to check your compressors power lines.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 13
過去 30 日: 30
今までの合計 129
1件のコメント
@innocentmutepfa have you checked your fuses? What have you checked and tried already?
oldturkey03 さんによる
