メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
What is wrong with my phone
I don't understand anything about my phone. When I am out driving around I don't have wifi from my data can you please just fix it asap please bl. I can't go without a phone because of my husband and I disability so please fix what ever is wrong thank you Leshia Watson
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @leshiawatson94
WiFi has a maximum range of about 100 metres (300 ft) for the 2.4GHz band and about 70 metres (200 ft) for the 5GHz band. It will be less if there are obstructions in the way e.g. walls, trees etc
If you are trying to connect to your home router's WiFi network when driving around, you won't get far before losing the connection. Also being in a metal box i.e. a car, won't help either as it is a further barrier to the WiFi signal.
If you are trying to use apps such as Whatapp etc to talk then it works on mobile phone data as well, but then data usage charges will be involved. It may be easier and cheaper just to make/receive a normal call from/to the phone when necessary.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Leshia Watson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 17
今までの合計 93
