Windshield washer not spraying
When I turn on the spray for my windscreen it doesn't turn on
Golf Mk5は2003年秋にヨーロッパで発表され、2004年初頭に英国市場へ投入されました。北米市場では、2006年の導入時にVolkswagenが再びRabbitの名称を使用しました。
@tlotlonfila it will help us to help you if you can tell us if it works in the back but not the front etc. Also, let us know if you hear the pump when you activate the washer.
If it does work on one side but not the other, we know it is not a fuse and not the pump. In that case you would need to check the tubing for any leaks etc. First check you want to do, is to see if you get water to the nozzles. Remove the tubing on the nozzle and see if you now get water coming out. If so, it's your jets.
If you have no water coming out, it could be the pump or the relay under the dash. Check this video for an idea on that.
Since we do not yet know what works and what dose not, the fuse for the windshield washer pump should be #41 (also check #46) in the passenger compartment fuse box. VW Golf Mk5 Fuse Box
過去 24時間: 0
過去 7 日: 7
過去 30 日: 26
今までの合計 170
