How to fix error message
Warning!!! USB device over current detected!!! Please remove over-current USB device!!! System will shutdown in 20 seconds!!!
@darkwrench that is usually caused by a shorted USB port. Check the port for any bend or broken pins. After that you will need to check the motherboard on the USB port for a shortcircut. The Dell™ Inspiron™ 531s Owner’s Manual includes how to be Removing and Installing Parts starting on page 101.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 21
今までの合計 190
