メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年発売、モデル番号「UX480FD」で識別可能。
Help with upgrading Storage and RAM
I am looking to upgrade Storage, and if possible, RAM.
When I contacted ASUS they said:
RAM: up to 16GB 2400MHz DDR4 memory (Please observe that the RAM is integrated and can´t be upgraded)
SSD: 128GB/256GB SATA III SSD
512GB PCIe x2 SSD
1TB PCIe x4 SSD
But I can not find the extra PCIE slots.
I only found 1.
Can anyone help me? Maybe find a schema for the motherboard? Or something.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi!
Correct, there is just only one PCI-E slot in there. So you can't install a extra SSD internally. You can only replace it for one with more capacity.
Maximum it can support is a NVMI PCI-E running at 4x - 1TB is the maximum supported memory.
Also, the RAM is soldered on the motherboard, so this cannot be changed.
You can find some more info here regarding the board: https://www.youtube.com/watch?v=5pIY1CRD...
Sorry for the bad news...
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Alright, strange of Asus to straight up lie about it tough... They are not very user friendly.. ^^
さんによる 共有
I think the person you spoke, does not have a clue regarding this model what it can support or what kind of ports are on there. Also this: "Maximum supported RAM is 16GB, please check if you can replace it all". You cannot replace the ram at all. The maximum config from factory was most likely 16GB. The one you spoke probably didn't have a clue regarding the board.
さんによる 共有
コメントを追加
回答を追加する
Christofher Vesterholm さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 36
今までの合計 270
