メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Meta Quest 3S 複合現実ヘッドセットは2024年10月15日に発売された、Meta Quest 3の後発の、廉価モデルです。
How do I fix meta quest 3s controller button?
画像
I got some wd40 to help with a stick drift issue, but some of the wd40 got onto one of the controller buttons, and now it's not responding to my input. I'm still able to press the button, but it doesn't make the same sound compared to the rest of the buttons on my controllers when i press them. It's been quiet after i heard a crunching sound when i pressed it after the wd40 i put on the joysticks was able to dry.
What do i do? Am i able to fix it, or do i need a new controller all together?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
my y buttin just stoped woking and i did not do angoning it looks fine on the outside i dont know what to do
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
Hi!
Sound like the contact of the button is damaged. Depending on which button it is, I would replace it completely and see what happens.
Otherwise replacing the controller is a option, but let's check what we can do first.
Can you also sent us some pictures regarding the button? Thanks!
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I edited my post to show a picture of the controller. It's the X button that isn't working. Nothing looks broken on the outside from what i can see.
How do i replace the contact of the button? Do i need to open up my controller to access the button contact?
さんによる 共有
Hi!
Yes, you need to open it up and check the button and rubber, clean it both with isopropyl alcohol. And please share a picture regarding the button inside the controller. Inside the controller is where you need to clean unfortunately.
さんによる 共有
I'll try to get my hands on some isopropyl alcohol soon. Do i need a certain tool/method to open up the controller? I don't wanna break the controller by accident.
さんによる 共有
Alright, great!
Yes, you need a Torx (T)5 screw driver, tweezers and a pry tool, like a spudger.
You can find everything in here: https://www.youtube.com/watch?v=EYa9UeDJ... Please follow this one to safely open your controller.
Please let us know how it goes!
さんによる 共有
コメントを追加
回答を追加する
Skitzo Phrenic さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 29
過去 30 日: 126
今までの合計 964
