Back glass replacement idea
Does it requires the transfer of the wireless charging coil and flash from the previous to the new ?
Yes, in most cases you’ll need to transfer the wireless charging coil and the flash assembly. They’re attached to the back housing and usually aren’t included with replacement glass unless you’re buying a fully pre-assembled rear housing.
You can see how it’s handled in the iFixit guide here:
That guide shows what’s part of the back assembly and what needs to be moved over.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 8
過去 30 日: 28
今までの合計 275
