メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
北米で2010年3月に発売されたニンテンドー DSiの大型版モデルです。ほとんどの修理作業はドライバー一本と開口ツールのみで完了できます。
Touch screen bezel coming off
Hi guys,
Lately I was having some problems with my DSI XL's touch screen "pulling" to the left of the screen when touching. I inspected the screen and I noticed the border / frame / bezel around the screen has come loose a bit from the adhesive that attaches it to the touch screen. I cleaned it from any dust and debris but it won't attach properly to the screen anymore.
How would I have a go at repairing this properly?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi!
First of all, without the border, does it work?
If not, I would replace the touchscreen completely for a new one.
Guide: Nintendo DSi XLのタッチスクリーンの交換
I would also get a new border from AliExpress. They are cheap and will stay on there.
Replacing is the best way to get it fixed, I'm afraid.
Please let us know how it goes!
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Hi Koppie,
Thanks for your quick reply. Yes after cleaning under the border it works again but I would like to prevent dust and debris from accumulating under the border! I've searched online for a replacement but not sure what search query I should use. Is it called a touchscreen border? How would you go about removing and cleaning it properly if you don't mind me asking?
さんによる
Okay that is good news!
You mean this > https://www.aliexpress.us/item/325680649... ?
You can get the "plastic color bezel" off it, I think (not sure).
Otherwise, if you buy a new shell, you will get it there as well. But then you need the exact same color as you are having now.
さんによる
I'll always leave the touchscreen and the bezel there and clean it from the outside, if that doesn't work, I need to take off the bezel carefully and put it on there, if this failed, I need to replace it..
さんによる
コメントを追加
回答を追加する
Teqhniq さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 21
今までの合計 133
