メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.0GHz, 2.3GHzもしくは2.6GHzクアッドコアIntel Core i7プロセッサ (Turbo Boost 最大3.8GHz) 6MB共有L3 キャッシュ付き。
Failures after battery replacement
I purchased a new battery from IFIXIT and also got the tool kit to use. I printed out the replacement procedure and followed it precisely, taking care along the way. It seemed straightforward and everything seemed to go as planned. Upon startup after replacement I now have these symptoms. It boots up very slowly now and pauses during the process, but finally does complete the process , Also the cursor is positioned at the top right of the screen and the track pad is not responding . The pop up box is showing up asking for user name input/etc but when I type on the keyboard , nothing happens. I can force shut down restart with the power button though. I was able to fully charge the battery (plus the additional charging that was recommended). Currently working on draining the battery as also recommended.
Also the fans are running at high speed during this whole time. Much louder than normal but not noisy just fast speed.
I took the bottom cover back off and inspected the cable connections on the logic board/etc. Nothing obvious found yet. The plug/jack connections look good, I didn't find anything obviously disconnected. I am thinking I might have to re-disassemble the unit to inspect more closely. Any tips on what I might have done wrong or damaged inadvertently ?
Thanks,
Dan
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
@danf30069 - Let's give this a try to see a bit deeper into the problem. Install this gem of an App CoconutBattery let's see what it tells us, take a snapshot of the Apps main window and post it here so we can see it as well.
さんによる
Thanks for the reply. Now it does not even boot up and gets stuck in a boot loop. Restarts and then tries to bootup and stops part way through. Then repeats this sequence. Took it to the Apple Store for further analysis and they couldn't resolve it either.
さんによる
コメントを追加
1 件の回答
The connection from the keyboard / track pad is not making a full connection causing the unit to go into a safe mode making the fans spin more. This will also make most of the keys without any function. Check the pins on the connecting cable(s) for any damage as this is likely the issue at hand. Carefully go over the guide again and pay attention to references to the track pad and keyboard connections. MacBook Pro 15" Retina Display Late 2013のバッテリーの交換
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dan F. さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 28
今までの合計 144
