phone wont install software
keep getting error ex080056 error or comething iphone 14
Hi, @georgemcneill I gotchu.
Put your device in recovery mode by doing the following: Press volume up, then press volume down, then press the power button until the Apple logo appears. When something unusual shows, connect your device to your iTunes-installed computer and when the pop-up apppears, select "Update" This will force-update iPhone.
このアンサーは役に立ちましたか?
Tip: If this suggestion does not work, then when the iTunes pop-up appears, elect 'Restore' then go through setup again and then try regular updates again.
My phone isn’t installing software updates. The installation keeps failing.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 37
今までの合計 154
