What causes boot failing
what causes boot failing
It looks like you're troubleshooting a Lenovo IdeaPad 110-17ISK that’s refusing to boot. Boot failures can be frustrating, but they usually boil down to a few specific "usual suspects."
Here is a breakdown of what typically causes a computer to fail during the boot process:
This is the most common hardware cause. If your Hard Drive (HDD) or Solid State Drive (SSD) is damaged or disconnected, the BIOS cannot find the Operating System (Windows) to load it.
Sometimes the hardware is fine, but the software is "broken." This happens if:
The BIOS (the motherboard's brain) might be trying to boot from the wrong place. If a USB drive or a disc is plugged in, the laptop might be trying to "start" from those instead of your hard drive.
If your RAM stick is faulty or has come loose, the system won't be able to handle the initial data needed to start Windows.
For Lenovo laptops, switching between "Legacy" and "UEFI" modes in the BIOS can cause boot failure. If Windows was installed in UEFI mode but the BIOS is set to Legacy (or vice versa), it won't boot.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 17
過去 30 日: 63
今までの合計 268
