メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
このページは、Sony PS2 Slimline (SCPH-750xx) のトラブルシューティングと修理ガイドのデバイスページです。Sony PlayStation 2 Slimline ゲームコンソールは、小型で薄型、ネットワーク対応のゲーム機です。
Optical Drive not working.
Heyy,
I had a PS2 Slim (Pink Version) SCPH-77004 with a broken shell (the rest was completely fine)
To replace the shell I ordered a defective and labeled as "Don't Reads Discs)"(Same Type, Same model of course) (might be a different MB Version, didn't checked)
The spare wasn't opened before. Like described it booted and was behaving normal in home screen, it didn't read a disc, but furthermore it didn't seem to even show life of the Laser Assembly (no Motor Spinning, no Laser movement)
That's when I started disassembly, first I checked/tested the two lid switches, both pressed, same result. Both tested good with a multimeter
I tried the working Assembly from my own Slim, and had the same result. The rail tested in my Slim showed Laser Movement and the motor was spinning up. (Didn't read discs, made clicking noises)
I did the same thing with the ribbon cable (so using the ribbon vice versa on both machines) which also provided the same results, I inspected the board of the Spare one and didn't saw any (obvious) issues. And I also checked the Ribbon connectors for lose (cold) connections.
The Spare also didn't looked dirty inside at all, it was like opening a never used console.
So in short:
Laser Assembly good
Ribbon cable good
Ribbon cable connectors good
No obvious MB issue (with Eyes)
Lid switches fine
My question now is, what could it be? Where could/should I start looking for an issue? Did anyone had a similar problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi!
Best thing is to follow this video: https://www.youtube.com/watch?v=Pthhet1_...
It can be way more then the laser and the lid switches (good thing you've checked those, as when they are faulty nothing is moving at all).
I would check your symptoms and see what issue it's having. I think it's something on the motherboard that died...
Can you let us know how it goes?
Thanks!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
TheToptic さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 97
