メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Charging port is broken
Charging port is completely broken
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Yes charging port is broken
さんによる
コメントを追加
1 件の回答
最も参考になった回答
There doesn't seem to be a lot of information out there about your particular speaker, so we may have to approach this from scratch.
First, we'll need to know what kind of charging port it has; most of them feature a USB port for charging, but that could be USB-A, USB micro or USB-C, or it could be a DC input jack.
Can you open up the speaker and access the circuit board the charging port is mounted on? If so, take it apart and take some pictures of the top and bottom sides of the board at a minimum; that way we can determine what kind of port and how easy or difficult it will be to replace.
If you haven't opened it yet and aren't sure how to, take some clear, high resolution photos of the front, back, top, bottom and sides of the speaker. That way we can try to determine the best way to open it up to access the charging port. This guide will help you add photos to your question.
Adding images to an existing question - iFixit Repair Guide
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi @dadibrokeit
According to the user manual it has a USB-C charge port,
Cheers
さんによる
コメントを追加
回答を追加する
Kenny さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 41
今までの合計 243
