メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
韓国製品のコードレスモップ、または床用スイーパー。
Autovis Replacement Charger Help, Please
画像
画像
画像
画像
My parents have misplaced the charger for this and I can't find where just the charger is sold. It is an AC 110-240V, 50/60Hz, but I don't know the mm of the plug in port to the device. Anybody know?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hi @jungune
Is there a product information label on the device somewhere? Near the charge port perhaps.
If there is, usually it specifies the voltage input requirements for the device i.e. DC voltage and polarity, (assuming it's not connected to AC voltage directly but through an AC/DC adapter).
Once that it known it makes it easier to find the correct adapter for it.
Post an image of the product label (if there is one) in your question. Here's how iFixitでの質問に画像を追加する方法
さんによる
Thank you! Yea, I was having issues uploading all the images. User error. I've uploaded it now. I can see the voltage, but I don't know the mm size of the plug in to the machine. Is it standard? Aren't they different diameters?
さんによる
コメントを追加
1 件の回答
ベストアンサー
You can get universal power adaptors online that come with all the common sizes of barrel jack. As @jayeff mentioned, make sure that it supplies the same voltage as is listed next to the power port.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I feel really challenged with this. How do I accurately measure the barrel jack? I guess if there are standard sizes, I go with the one that's closest to it? For some reason, I'm thinking if I'm a millimeter off, it won't fit, but I haven't even looked to see what sizes exist. 😅
さんによる
コメントを追加
回答を追加する
Jungun E さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 22
今までの合計 161
