Location of Wireless Charging Coil?
I'd like to know the exact position if possible?
The best I've found is page 152 of the repair manual, https://support.google.com/product-docum...
You found it. It's under a mylar sheet on the inner housing. That round donut shape is quite distinctive; that's exactly what a charging coil looks like. Just to clarify, I've marked the donut shape for you.
このアンサーは役に立ちましたか?
How about looking at if from the other side? Basically locate the published case / charging system guide published by Google which likely requires you sign a NDA to get.
Here's a deeper writeup on Qi PCH Wireless Charging Device
You might find getting magnetic sensitive sheet can help you locate the magnets which aligns the phone to the charger 4x6 Green Magnetic View Film - Visualize Magnetic Fields and Patterns
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 16
過去 30 日: 56
今までの合計 365
