メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Theragun Miniは、筋肉の痛みを和らげ、緊張を軽減し、全体的な筋肉機能を向上させるために設計された、ハンディ型のパーカッシブマッサージセラピーデバイスです。
Thereagun Mini (2022) Dead Battery?
My wife has a Theragun Mini from 2022 that no longer turns on and/or holds a charge. So of course, I came to iFixit for the teardown and I was sad to see there wasn't one.
Does anyone have a repair or tear-down guide for the 2022 what I guess is the original Theragun mini?
I found this video here which showed the result of cracking open the case. However, it doesn't show him putting it back together. HA!) You can hear him describe his theory as to the battery type possibly being three Panasonic 3400mAh batteries run in series (based on the tennis ball yellow/green color). He later reads a part number "31NR19/66" which unfortunately come in a range of sizes. And finally, he mentions that "they look like 18650s to me" which seem like a technical form factor.
While I'm not surprised that a 4 year old electronics product has died, I am very disappointed in Therabody for designing a product so aggressively anti-serviceable by an owner or third party.
Any advice or help would be greatly appreciated. Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Check out this threat from Oldturkey: How do I open the Theragun mini?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thank you, I did see it, but there wasn't really much of a resolution.
さんによる
OK, I just thought it might be a good starting point! I haven't taken apart this theragun but have repaired their classic model. My advice is to go slow and use a heat gun or even just a really hot gel pack to try and loosen the adhesive. Be careful not to overheat the area of the tool wheere the battery is. Don't stress too much about bending/cracking the plastic since the rubber casing will cover most of it. Any cracks that do appear can be fixed easily with some Jet Glue/Super Glue and covered with Rubber Cemenet or Sugru
さんによる
@daddysnorlax it's glued together like crazy :-) check this video before it disappears as well. Theragun does not like us fixing things :-)
さんによる
コメントを追加
回答を追加する
Daddy Snorlax さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 37
過去 30 日: 152
今までの合計 1,006
