メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2023年初頭に発売された、Lenovoの14インチのエントリー向けビジネスノートパソコン、Lenovo ThinkPad E14 (AMD) 第5世代の修理ガイド、分解情報、およびトラブルシューティング情報。
LCD Backlight not working. Potential blown fuse.
I checked for continuity. The issue is here (F1 fuse) but I'm not sure if it's missing.
My question is if someone can circle where the backlight fuse F1 is located in this photo?
画像
Thanks.
Update (01/13/26)
I couldn't find Fuse# 3A_32V_0497003PKRHF.
I found a replacement that I believe is very similar.
Will this replacement Fuse work?
画像
Thank you again for your help. I really appreciate it.
Update (01/14/26)
After further inspection of the schematic posted,
It looks like c310 and c313 are missing on the NM-F351 motherboard.
Could c310 and c313 missing cause the dim backlight on the LCD?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @rickfix2026
If the motherboard is model number NM-F351 (printed on the board), below is a composite image (whole board - top and zoomed in section of board - bottom) from the NM-F351 boardview file showing the location of the F1 backlight fuse (fuse type # 3A_32V_0497003PKRHF).
画像
(click on images)
Update (01/14/26)
Hi @rickfix2026
Run the LCD self test and check if it works OK just in case it is not a backlight power supply problem but something else e.g. problem with the backlight enable circuit on the motherboard (connects to pin 49 EDP connector)
If the test proves no good, here's an image of the schematic showing the backlight power supply through the fuse to pins1-3 on the EDP connector on the motherboard.
With the laptop turned on etc, check what voltage is on those pins.
The feed states V9B+ so maybe it should measure 9V DC but as to why so many capacitors are sitting on the supply line I don't know. Maybe need to smooth out the supply.
If one of the other capacitors on the line i.e. C19, C10, C307, C314 & C315 was faulty and shunting the voltage to earth this may be the reason for it being faint
There may be a lot of current flowing (Amps) so try not to short the pins to anything else when testing for the voltage.
If the correct voltage is there you may have to disassemble the display unit and check what the voltage is on pins 1-3 at the other end of the EDP cable where it plugs into the LCD panel, in case the cable has been damaged where it passes through the hinge to get from the motherboard to the lid.
If the voltage at the LCD panel is OK then most probably it's a faulty panel which would have to be replaced.
Here's the hardware maintenance manual.
Go to the bottom of p.82 (89 of 108 pdf) in the manual to see how to remove the LCD unit
画像
(click on image)
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Yes. The motherboard is NM-F351.
Thank you for confirming.
さんによる
@rickfix2026
The fuse you linked may be a bit small in that it may not bridge the distance between the two soldering point on the motherboard.
Here's a link that shows the common smd package sizes that may help.
You have linked a fuse (which has the correct rating 3A/32V) with a package size of 0402 (see link).
The 0497 size shown for the part is a non standard size so it may be easier to get one a fuse that's slightly longer so as to bridge the gap but not too wide as not to touch any other components on the sides (or the ends either)
Possibly a 3A 32V 0603 fuse perhaps
さんによる
@jayeff looks to me like the white (far right vertical component) is F1 and the middle component that looks smushed ;-) (missing) would be C310 which is a 0.1µF 25V capacitor in a 0402 and is part of the LEDVDD circuitry right next to F1 :-)
さんによる
@oldturkey03
probably right - old eyes ;-(
It's a bit different to the boardview but the OP confirmed the board model number
さんによる
@jayeff I know, me too ;(
Had to zoom in quite a bit ;)
the board view is vertically flipped. The board number is right.
さんによる
コメントを追加
回答を追加する
Rick さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 31
過去 30 日: 124
今までの合計 724
