surface pro 4 battery replacement
Do all model of Surface pro4 use the same battery because I am not sure if would order a correct one?
Yes, all models of the Microsoft Surface Pro 4 use the same battery.
The Surface Pro 4 (model 1724) has a single battery design across all configurations (Core m3, i5, i7; different RAM/storage options).
The battery specs are consistently:
Common part numbers include:
This is confirmed by repair services, iFixit replacement parts, and listings on sites like Amazon and eBay, which all reference the same compatible battery for the entire Surface Pro 4 lineup. You can safely order a replacement battery labeled for "Surface Pro 4" or "model 1724" without worrying about variations between sub-models.
Tips for Replacement
Battery replacement is possible but challenging. It involves heating and removing the glued screen (high risk of breakage), disconnecting components, and carefully handling the strongly adhered battery.
このアンサーは役に立ちましたか?
過去 24時間: 8
過去 7 日: 13
過去 30 日: 62
今までの合計 388
