メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy S24 Ultraの修理、分解、トラブルシューティング情報です。Samsung Galaxy S24 Ultraは2024年1月に発売された、2024年のSシリーズラインナップの中で最大のスマートフォンです。
How to replace motherboard
My phone was diagnosed by samsung but out of warranty by a month and was going to cost $500. That was out of the question, when I am still paying on the phone and haven't had it for a year. My phone looks brand new still and started overheating, while not keeping my battery at a full charge. The phone overheating causes the phone to shut down about every 60 seconds. I was going to pay to have it fixed when samsung sent me to asurion but samsung said I needed to mail it in. It took 2 weeks for them to reply with an update after receiving my phone and said the same as asurion, it was the motherboard. This was the phone, nothing I did but from the factory.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Replacing the motherboard in your phone is fairly straight-forward, at least as far as phone repairs go. Although iFixit doesn't have a guide specifically for that repair, you can use the Screen and Battery Assembly Replacement guide to get to it and remove it. Obviously there'll be steps you'll want to skip, such as removing the daughterboard, but other than that, the guide will get you there; just use some common sense with regard to which parts need to come out.
Although I'm inclined to think that two separate shops coming to the same conclusion that the motherboard is at fault is probably right, personally I would be tempted to try replacing the battery and see if that fixes the problem. Without those diagnoses you got, that would be the first thing I would have tried. Batteries aren't terribly expensive; certainly they're far cheaper than a new motherboard, so I'd give it a shot, but of course that's your decision. If you want to try, here's the iFixit guide for that repair.
Samsung Galaxy S24 Ultra Battery Replacement - iFixit Repair Guide
I am a bit confused by your warranty situation; you said you haven't had it for a year, which is the normal length of the warranty, but you started out by saying it's a month out of warranty, so am I missing something?
Anyway, good luck with your phone, and be sure to come back and let us know how it all turns out; your experience could help the next person who comes along with the same problem.
Samsung Galaxy S24 Ultra スクリーンおよびバッテリー一体型ユニットの画像
ガイド
Samsung Galaxy S24 Ultra スクリーンおよびバッテリー一体型ユニットの交換
難易度:
中レベル
1 - 2 hours
Samsung Galaxy S24 Ultra バッテリーの画像
ガイド
Samsung Galaxy S24 Ultraのバッテリー交換
難易度:
中レベル
45 minutes - 1 hour
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Brittany さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 25
過去 30 日: 95
今までの合計 1,085
