Blue screen of death
この質問は役に立ちましたか?
This is bad, very bad. Your machine lost key data on the TPM and now it wants a 48 character Bitlocker key, one which lost means complete data loss unless you can recover the key. See if you can get the key from this site if you used a MSA: https://account.microsoft.com/devices/re... -- if you used a local account, you're done unless you have a copy of the key locally.
If you can't get back in, use this guide to make a bootable drive: Windows 10/11 - USBインストールメディアの作成 (Rufus) or Windows 10/11 - USB インストールメディアの作成 (Microsoft MCT)
If you want to be sure sure the drive is clean, use this to securely wipe it: SSDおよびeMMCの診断と消去 - Debianベースのディストリビューション、Parted Magic Legacyおよび2026+ビルド
I have seen this on the 64X G9 and G10 series (not my G11) but you probably should buy a mouse... Some Synaptic chips do not work well in the installer, and my HP G9 series machines were there, G6 and older weren't affected and G11 fixed it again.
ガイド
難易度:
簡単
30 minutes - 1 hour
ガイド
難易度:
簡単
1 - 6 hours
ガイド
難易度:
簡単
30 minutes - 1 hour
このアンサーは役に立ちましたか?
I HAVE NO KNOWLEDGE OF BITLOCKER AS I HAVE NEVER USED IT
According to the image provided, you need to enter a security key. Microsoft says at aka.ms/myrecoverykey, you can find the key at https://account.microsoft.com/devices/re... if it was linked to your Microsoft account. If it was linked to a work or school account, go to https://aka.ms/aadrecoverykey. Printout and USB drive options are available so I would look for any items. If you cannot access or find your key, you will have to reset your computer which will erase all of your data.
I’m sorry if this does not work or the outcome has disappointed you, I’m only young (teenage), or if it has you are very welcome.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 23
今までの合計 211
1件のコメント
[image|3935181]
Casey teska さんによる
