メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony ICF-C1PJButtons not responding
I have FM/AM Clock radio Sony ICF-C1PJ. When I plug in this device, clock's digit are blinking but buttons are not responding.
Any ideas? If needed to repair the buttons, please advice how to disassembly it. I have managed to open a cover, but further I don't know how to reach the buttons.
Thank you in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Step 1: Basic reset check
  1. Unplug the device from AC power.
  2. If your model has a battery backup, remove the battery (usually a CR2032 or AA/AAA cells).
  3. Wait 1–2 minutes.
  4. Reinsert the battery (if present) and plug in the device.
  5. Check if the buttons respond.
Sometimes blinking digits are a reset signal, and unplugging/resetting may fix it.
Step 2: Check for stuck buttons or debris
  • With time, dust or sticky residue can prevent the buttons from registering presses.
  • Inspect carefully around each button. If you see dirt or sticky residue, try gently cleaning with isopropyl alcohol and a cotton swab.
Step 3: Disassembly to access the buttons
Since you already opened the outer cover:
  1. Remove the screws on the bottom and/or back of the unit. Keep track of their positions.
  2. Carefully separate the top cover. Usually, the buttons are mounted on a plastic membrane sheet that sits on top of the main circuit board.
  3. The buttons themselves are often conductive rubber pads. If these pads are misaligned or worn, pressing won’t register.
Important tips while opening:
  • Take pictures at each step so you can reassemble correctly.
  • Be gentle with ribbon cables—they are fragile.
  • Note the orientation of the speaker and projector assembly (if your model has a clock projection).
Step 4: Test button contacts
  • With the cover off, locate the rubber button membrane over the PCB.
  • Press each pad with your finger or a plastic tool. You should feel a small click.
  • If a button is not responding, check the PCB underneath:
    • Sometimes the copper pads are dirty or corroded.
    • Clean lightly with isopropyl alcohol.
    • If pads are worn, you may need to replace the button membrane, which may be sourced from Sony parts suppliers.
Step 5: Reassemble and test
  • After cleaning and checking the buttons, carefully reassemble the device.
  • Plug in and see if the clock stops blinking and the buttons work.
💡 Extra tip: If the buttons are completely unresponsive even after cleaning and pressing directly on the PCB pads, the issue may be internal to the control board, possibly a failed microcontroller or solder joint. In that case, unless you’re comfortable with electronics repair, it might be simpler to use it with a new clock radio.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The matter is that all buttons are clicking. The problem is I know how to take off PCB from their places even I opened a cover. I need a help how to disassemble this device due to closer to inspect PCB.
さんによる
コメントを追加
回答を追加する
Linas Maksvytis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 19
過去 30 日: 65
今までの合計 389
