メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhoneの第5世代モデルの修理情報とガイド。モデル:A1387
iPhone 4s keeps boot looping
My apologies for the very long post. I recently got myself an iPhone 4s for cheap. However, it keeps repeatedly showing the apple logo for a few seconds, and then it turns off. It does this repeatedly not matter how long I charge it. It doesn't even hold a charge so when I unplug it, it'll instantly turn off and won't turn on until it's charging again, even after I left it on charge for hours. At first I thought it was the battery so I bought an ifixit battery, but it still boot loops even after replacing the battery and cleaning the contacts with isopropyl alcohol. Luckily I had an old beaten up iPhone 4s at hand which still turned on and charged but the screen wasn't doing too great. I tried the ifixit it battery inside the old beaten up 4s and it charged and held the battery fine. Even the original battery of the boot looping 4s worked fine in my older beaten up 4s. Does anyone know what I can do from here or is this a lost cause? Any advice would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hi! It sounds like it's either a logic board, battery connector or software issue. Here's what I'd try:
  1. Try a force restart using the power and home button at the same time until the phone reboots
  2. Try restoring the phone with iTunes using the desktop app.
  3. if neither of these works you likely need a new logic board sadly. You can use this guide for a logic board replacement: iPhone 4S のロジックボードの交換
Hope this helps! -Kieran
Also, a long detailed question like this is better than a short one that doesn't explain it well :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joshua Balibuno さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 20
過去 30 日: 71
今までの合計 490
