My back comera is shaking while use
When the camera is use is shake like none stop
It sounds like the camera might need to be replaced. Either the iPhone 11 or the iPhone 13 (I can't remember which) had a problem similar to what you're describing, which was caused by stress on 4 tiny wires that helped to stabilize the camera from shaky hands and other vibrations. Said wires were very prone to breaking, which rendered the stabilization system useless. I wouldn't be surprised if the Air used a similar, if not identical, system. If you were using your phone on a motorcycle or something like that, or maybe just shook it really hard or something, I'd say there's a good chance that the stabilization system is busted. Unfortunately, the only way I can think of to fix this is to replace the camera.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 31
今までの合計 131
