メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung RFG298HD** 冷蔵庫の修理および追加情報。このモデルは、引き出しとドアの両方からアクセスできるボトムフリーザータイプで、製氷機を内蔵しています。このページでは、RFG298HD** に該当するモデル番号の情報を扱います。
Auto defrost is not working
There is a 3s press switch for defrosting and it is working. But auto defrost is not working.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @umchbh
Here's the RFG298HD service manual.
Go to p.51 (52 of 105 pdf) to view the self-diagnostic function during normal operation procedure and check if any error codes are shown.
Reason for trying this is because manual defrost may override any inputs that are used by the control board to determine that a defrost cycle is required. It just checks that the defrost circuit is working OK, not that a defrost cycle is required..
Which compartment is not defrosting at all or is it just not defrosting that often?
According to the RFG298HD Fast Track troubleshooting guide, the refrigerator compartment defrosts every 6-11 hours (varies according to the conditions)¹and both the refrigerator and freezer compartments defrost every 12-22 hours (varies according to the conditions)¹ - see p.3
Basically at a minimum the refrigerator compartment should be defrosted twice approx. every 24 hours and the freezer compartment only once
¹ The refrigerator uses what is known as the adaptive defrost cycle method instead of the accumulated compressor run time or the simpler fixed time period methods. With the adaptive defrost cycle method the time interval between defrost cycles is determined by how often and for how long the doors have been opened and the ambient temperature where the refrigerator is located. It is considered to be more energy efficient than the other two methods.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Umchbh さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 11
今までの合計 135
